    Mar 2009
    Charlottesville, Va.
    Default Others markings for Tempered glass
    Are there any other markings or acronyms used to indicate that a pane of glass has been tempered ?
    The picture is of a window next to a jacuzzi tub.
    Default Re: Others markings for Tempered glass
    Looks like Low E glass to me.
    Last edited by Jerry Peck; 07-09-2012 at 05:25 PM. Reason: rotated photo for better reading
    New York
    Contact Cardinal Glass Products and ask them what this particular stamp (etching) signifies.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    "Cardinal Glass Industries is mnagement-owned S-Corporation leading the industry in the development of residential glass for windows and doors. We have grown to more thn 5,500 employees located at 27 manufacturing locations around the United States"...
    "We provide a turnkey solution to window manufacturers: whether it starts with insulating glass, coated, laminated, tempered or just plain float glass, it is all designed to provide the latest in applied glass science."
    Company structure
    Cardinal Glass Industries is a corportion with these wholly-owned subsidiaries:
    Cardinal (R) IG - Cardinal IG Compny (insulating glass)
    Cardinal (R) CG - Cardinal IG Compny (coated glass and optical mirrors)
    Cardinal (R) LG - Cardinal LG Company (laminated glass)
    Cardinal (R) FG - Cardinal FG Company (float and tempered glass)
    Cardinal (R) ST - Cardinal ST Company (solar technologies)
    Cardinal (R) AG - Cardinal AG Company (automation equipment)
    I would source the actual window manufacturer - as Cardinal supplies to spec multiple manufacturers for residential fenestration.
    It appears the particular is marked as having been produced by the Insulated Glass Division, and that it is further E2. It may or may not be safety or wind force as a unit. Fully tempered is only one form of safety glass.
    If it doesn't say tempered then I'm not going to guess. I write that I was unable to verify it's presence. As for calling the manufacturer - I'll let the client pursue that.
    New York
    I agree that if it does not state "Tempered", as far as my inspection is concerned, it is not tempered (although it could be).
    If I felt contacting a manufacturer would be helpful, in many (if not most) cases, I would have no problem making that call.
    An insulated glass unit can employ tempered glass, laminated glass, or even plain float glass, with or without lo-E coatings or films.
    Examples IG units made from laminated glass for sound attenuation - (near highways, airports, etc.) and IG units made from laminated glass for hurricane/high wind resistance.
    Tempered glass isn't the only form of safety glass. Just because glass may have been heat tempered doesn't mean it is safety glass (it may just be simply stronger (more resistant to breakage) than anealed glass, but still not meet the requirements for tempered type "safety glass").
    The window or door manufacturer specifies the glass/glass units manufacturered for them by Cardinal.
    Contact the manufacturer of the fenestration unit itself. If appears replacement look for additional markings and/or permit history, loss history reports, inquire of HO, to find specific information necessary to trace/track.
    Look for additional logoing referencing in another corner or sash such as "SGCC" as Cardinal uses the Safety Glazing Certification Council for independant certification of their safety glazing panels.
    The IGCC & IGMA logoing (and the CBA rating) are references to IG performance standards.
    Manufactured first quarter 2002, in CIG plant 4.
    Markings and logoing changes in effect subsequent to the IG unit manufacture date.
    Perhaps the attached might help as you endeavor.
    Attached Files Attached Files
    Mar 2011
    Sparks,NV
    Tempered glass often has a wavy appearance. This is not a definite way to tell but just an FYI.
    Nevada IOS#1730
    Nevada Energy Auditor #30
    775-342-4767 www.homecsi.com
    Quote Originally Posted by Robert Ernst
    Meaningless and offers absolutely no indication.
    Heat Tempered (strengthing) does not equate to fully tempered ("safety" only if passing tests/bearing certifications to same).
    Anealed (also strengthing via heating and cooling).
    Coatings - spot or film/laminations can also distort clarity
    Heck even float glass can have imperfections including "wavyness".
    Distortions, "waviness" roller direction distortion, clarity, is NO indication of the strength, impact resistance, etc. of fenestration.
