    Default voids in block foundation
    Default Re: voids in block foundation
    No takers on this, eh?
    OK, I'll give you my thoughts.
    I've never seen it either.
    Nota clue, nothing, zilch.
    I haven't seen those before either, but I can see potential firewall/fireblocking issues with them.
    Didn't see your post yesterday, spent most of the day at various eye-doctors, ending up at a retinal specialist due to concerns I may have a detached retina (not a good thing), but the ending opinion is 'probably not, but if I see anything changing to call them immediately (they put emphasis on the 'immediately' part), and go back in 2 weeks if nothing further happens so they can check again.
    Thanks, Jerry, and best of luck with the eye issues!
    Yeah, Doc says;
    Take two aspirins and see me when you more money.
    Anyhow, wish you well.
    Looks like regular block instead of L-corners.
    Clarksville Home Inspection
    JW Goad
    Holladay, UT
    Apprentice who does cuts was out sick that day. Anybody else having trouble with boxes above text (fonts, ABC etc.) not working?
    http://acloserlookslc.com/
    Jul 2010
    Wisconsin
    Masons ladder to climb out of the hole...
    Good luck with the eye, don't look at the sun.
