05-02-2013, 11:31 AM #1
I believe it's a flu liner issue, not sure what's causing all the moisture
I have an area of wall about 6ft x 4ft that is retaining moisture. My chimney is on the outside of the wall. I have had it professionally capped with concrete, new roof, tuck pointing, flashing and new gutters but nothing seems to stop the moisture coming through the wall. It is constant and seems to be getting worse, when I put my hand on the wall the plaster is wet and comes off on my hand. I have a Tru-Lite chimney liner for my flu, it was installed in 2006, could a flu liner come apart and the gases cause condensation to this extent?
Thanks,
Jeremy
05-02-2013, 01:47 PM #2
Re: I believe it's a flu liner issue, not sure what's causing all the moisture
05-02-2013, 05:32 PM #3
None of us want the flu,but the chimney,flashings,etc may be the problem.
05-02-2013, 07:33 PM #4
Like Scott says; post some pictures. Also include where the roof meets the chimney.
05-04-2013, 04:59 AM #5
It could be condensation from a LPG appliance.
What are you burning? Is it a fireplace or an appliance?
Does the wall feel colder than other walls in the house?
When does the wall get wet?
