    Al Roden's Avatar
    Al Roden Guest
    Default Distance from Exterior Light Bulbs to Combustibles?
    Are there minimum distance requirements for light bulbs installed on the exterior?
    Default Re: Distance from Exterior Light Bulbs to Combustibles?
    Quote Originally Posted by Al Roden View Post
    Check fixture manufacturer for any recommended installation distance.
    *as shown it's a Fire Hazard
    Common sense (well in this case its absent) bulbs should not touch combustibles.
    Simple fix!
    yes, but are those combustible? Metal or cementitious siding it looks like.
    Oct 2008
    Tulsa, OK
    Attachment 29102
    This is about as much info as you can get from a manufacturer. Recommend LED lamps. The NEC asks for 3 inches clearance in unrelated references.
    It does have a texture.
    *Whats the thickest material made ?
    **here's another view
    Thanks Billy, Now I'm dizzy I'm going with metal siding. Cementious would not have the detail at the edge.
    Sep 2008
    so so, California
    410.115 Temperature.
    (A) Combustible Material. Luminaires shall be installed so that adjacent combustible material will not be subjected to temperatures in excess of 90°C (194°F).
