    Default Wood Floor Inspection-Ewa Beach, HI 96706
    We have an immediate need for an inspector to inspect a wood floor in Ewa Beach, HI 96706
    The complaint is for boards being released from a concrete floor. You are required to have a moisture meter (non-invasive will work, having a pin meter in addition will be a plus). Temperature and humidity readings required along with pictures. You must have some knowledge of wood floor installations.
    Payment will be made within 10 days of completion of the inspection.
    You are responsible for setting the appointment. The inspection report must be submitted on our website within 48 hours of the inspection.
    Inspect Solutions, Inc. has been contracted to provide national inspection services for major retailers and manufacturers.
    Our clients are major retailers or manufacturers that just want to know what is wrong so the problem can be taken care of. They also need our opinion so the proper party can be charged back. For example, if it is a major box store inspection and it is an installation related issue, our reports are used for the reason of the chargeback to the installer.
    We have our own secure-web based program that you will upload the photos. You will also complete the report online. Our web-based program is extremely easy.
    Contact Ron Gould via email at rgould@inspectsolutions.com or (888) 854-0946.
    Inspect Solutions
    Default Re: Wood Floor Inspection-Ewa Beach, HI 96706
    The following should ring some bells with installers (I would hope anyway):
    (bold is mine)
    Quote Originally Posted by Ronald Gould View Post
    Ewa Beach, HI
    Why would you glue down a wood floor to a concrete slab near a beach?
    And this is why my company exists..........................................
    roger gerber's Avatar
    roger gerber Guest
    Ron, send a ticket and I'm there.
    Try Paul Signore:
    Paul L. Signore Building Inspection Services Inc.
    Paul L. Signore, Office: 808- 876-0170 Fax: 808-876-0363 pjsignore@hawaii.rr.com
    I have no idea if he is even on the same island, but he knows every inspector in the islands and should be able to help.
