Thread: Gas hot water heater draft hood
07-31-2013, 12:21 PM #1
07-31-2013, 01:03 PM #2
Re: Gas hot water heater draft hood
While most water heaters do have a draft hood, direct vent water heaters do not.
https://www.google.com/search?q=dire...hrome&ie=UTF-8
https://www.google.com/search?q=dire...w=1510&bih=775
07-31-2013, 03:52 PM #3
It is a mechanical draft.
07-31-2013, 06:49 PM #4
Mechanically vented gas appliances can NOT be vented into 'B'-vent as it is not designed or approved for positive vent pressure. Yes, please post pics when you can along with make and model. Some WHs are designed as natural vent but guys install aftermarket power vent kits, which are not approved unless tested and listed for that model appliance and vented with listed gas vent for positive vent pressure or other material such as PVC if specified and approved by the mfr.
08-03-2013, 05:29 AM #5
08-04-2013, 10:19 AM #6
VSO is free it comes with windows 7 and above
08-05-2013, 01:05 PM #7
any back pressure from the roof top will blow out the pilot light if there is one.
