Thread: Location of Main Panel
08-13-2013, 03:45 AM #1
08-13-2013, 08:20 AM #2
08-13-2013, 04:12 PM #3
Re: Location of Main Panel
I missed the part about inside the cabinet earlier. No way it has the proper work space in front of the panel if it's actually inside the cabinet.
08-13-2013, 06:52 PM #4
We require 36 inches of space in front of the panel,as a working space.
08-14-2013, 04:14 AM #5
08-17-2013, 04:30 AM #6
Think that I commented about this drawing a while back as being totally useless as an example. It is missing a critical dimension---the depth of the minimum space required in front of the panel that is usually 36". The only good piece of information is that the 30" minimum is a sliding space.
08-17-2013, 06:43 AM #7
No problem. But as an informational drawing it sucks. Better not to use it for anything. As you know, a drawing will always get separated from any included text. Then the confusion/issues start. Better if the information was in a callout on the drawing, and also referencing the standard.
When I was designing, I used 4'. The sparkies always liked 5', and when that was obtainable---they got it. They always said that the larger distance was for them to recover from being thrown across the floor from a shock!
08-19-2013, 01:18 PM #8
"Panels may no longer be installed on the wall space above a countertop, nor can they be inside a kitchen cabinet or other cabinet." "Electrical Inspections of Existing Dwellings"
