    Sep 2011
    Sarasota, FL
    Default When were bollards first required
    When were bollards first required for gas water heaters in a garage?
    Default Re: When were bollards first required
    Quote Originally Posted by Jim VanSuch View Post
    Really does not matter when, but that they are needed to protect the gas water heater.
    Sep 2007
    Fredericksburg, VA
    It sounds like Jim ran into a realtor or seller complaining that protection wasn't required when the house was built. I wonder how they know? I agree, it's a safety issue just report as such with a short explanation as to why and let the buyer decide.
    Stu, Fredericksburg VA
    Contact the AHJ or local gas company. They might be able to tell you.
    Mike Lamb
    Inspection Connection, Inc.
    Read the installation instructions - bollards are typically required by the installation instructions and the code goes with the most restrictive of either the installation instructions of the code - so even if the code did not call for bollards but the installation instructions do ... then bollards are required.
