Results 1 to 21 of 21
Thread: Flir E4
    Oct 2012
    Burnaby, BC, Canada
    Default Flir E4
    I am a new home inspector, planning to buy a Flir E4 Camera. Dose any one has used it? Dose it pick up the floor heating flow? Thanks.
    Sep 2008
    so so, California
    Default Re: Flir E4
    Quote Originally Posted by Gordon Lee View Post
    You want to see water moving?
    Default Re: Flir E4
    I think he is referring to in-slab heating and he wants to be able to see the heat pattern of the piping.
    New Mexico
    Default Re: Flir E4
    Not familiar with the E4, but my old B Cam picks it up very easily, so I would think that camera would as well.
    Aug 2011
    Default Re: Flir E4
    An IR camera will show radiant floor heating coils, pipes, etc very well. Sure beats crawling on the floor.
    Dec 2011
    Pennington nj
    Default Re: Flir E4
    I got an E5 from Flir direct. It picks up a lot of stuff... look at flir direct b/c you get freebies with the purchase.. I got a $200 moisture meter w/ mine... I do not have any stake in flir direct, just a happy customer.
    Sep 2008
    so so, California
    Default Re: Flir E4
    One of these is electric in floor and the other is hydro. Both with flir
    Aug 2011
    Default Re: Flir E4
    Looks like the guy laying out the hydro lines was in a hurry to finish on a Friday evening.
    Default Re: Flir E4
    Under good circumstances the FLIR E4 should easily see the hydronic lines. This assumes they are not too deep in the concrete, and that the heat has not been on for a long time. If the slab has been heating for awhile the E4 will have more trouble differentiating exactly where the lines are since the concrete will be more evenly warm. Here's a link to a blog post I wrote for Ivy Tools comparing the images of the E4 E5 E6 and E8. You can see that the E4 has considerably less resolution, but since you know where to look and can control the conditions, the E4 can get the job done in this situation.
    Default Re: Flir E4
    Right now I would caution anyone about buying and using any IR during a home inspection as long as we have the patent trolls lurking in the shadows. The manufacturers don't care, but they are not the ones who will have to defend themselves.
    Default Re: Flir E4
    Scott,
    Do you know when the patent was issued?
    I ask because I suspect that my use of the IR camera during inspections predates their patent, in which case the use of IR in inspections was common knowledge and common knowledge is not allowed to be patented. Also, it was part of my promoting and advertising (word-of-mouth advertising) and business model ... I give anyone and everyone permission to keep my business model and promoting and advertising methods going for inspections.
    I would be willing to testify against those patent trolls if the dates worked out as I suspect the dates would.
    Of course, though, that would still require an attorney to crush the patent trolls once and for all.
    Aug 2011
    Default Re: Flir E4
    I was completely unaware of this.
    http://www.greenbuildingadvisor.com/...frared-cameras
    Commentary in the article speculates that Nick Gromicko's actions may make this worse.
    And more.......
    Patent Lawsuit Threatens the use of Infrared Cameras for Home Inspectors | The Home Inspector | StarTribune.com
    And for anyone's reading enjoyment, the actual lawsuit.
    http://optimalbuilding.com/files/Hom...Inspection.pdf
    Default Re: Flir E4
    The E4 will work, but it is so low rez that you will have to walk all of the floor for a closer look = more time. Seeing the individual coils gets obscured by carpeting, furniture and if the concrete temp has stabilized to the same temp as the cooled water in the coils, it becomes one big blur. It's the blur that shows a leak BTW. Ideally, turn on the heat first in a cold (low 60's) house and wait a few hours or at the end of inspection to pull out the IR camera.
    Default Re: Flir E4
    Scott,
    Jerry, I don't have the exact date but it was back around 2002 if I'm not mistaken. They have also subsequent additions for a total of around 5-6 patents that can impact home inspectors and just about anyone using an IR camera on a residential structure regardless of what they are doing.
    This is a breakdown of what is being faced:
    Patent No. 7,369,955 - Residential Indoor Environmental Quality Inspection Method: This patent covers the usage of an infrared camera to locate any thermal anomaly - including but not limited to an uncontrolled or hidden water intrusion - in conjunction with obtaining data relating to indoor air quality, including visual confirmation of mold, collection of mold samples, measurement of relative humidity, installation of a constant air/gas monitor system and/or other measurements including air pressure measurements. A thermal anomaly is an unexplained difference in temperature from one area of a house to another, often indicating a problem that can't be detected by ordinary means. Thermal anomalies signify a problem with faulty wiring, hidden moisture, missing insulation, heat/energy loss, termite infestations and more.
    Patent No. 7,445,377 - Non-Destructive Residential Inspection Method and Apparatus: This patent covers HomeSafe's method for creating a "thermal window," that is, preparing a house for an IR inspection by creating a temperature differential between the inside and the outside of the house, followed by obtaining temperature profiles of the house's interior and exterior components. These temperature profiles are then analyzed to uncover thermal anomalies indicating problems such as moisture intrusion or electrical issues. This method helps to create more optimal conditions for efficient usage of IR and better interpretation of IR data in the inspection process.
    Patent No. 7,385,483 - Infrared/Acoustic Method to Detect Termite Infestations in a Structure: This patent covers HomeSafe's four-step procedure for uncovering termite activity in a building, including: 1) a traditional visual inspection; 2) infrared detection of hidden moisture that may indicate the presence of termites; 3) usage of a moisture meter to confirm the presence of moisture in the "suspicious" area identified by IR; and 4) usage of HomeSafe's pattern recognition software to analyze and confirm termite signals on the spot.
    Patent No. 7,434,990 - Additional Methods to Detect Termite Infestation in a Structure: This patent covers the use of infrared scanning to detect moisture associated with termite infestations followed by other methods, i.e., a microwave motion detector, gas detector or termite-sniffing dogs, to confirm the presence of termites.
    Patent No. 7,271,706 - Termite Acoustic Detection Device: The patent covers HomeSafe's acoustic termite detection device which utilizes powerful acoustic (listening) sensors to literally hear termite sounds that are beyond the range of human hearing. Paired with IR scanning to find hidden moisture associated with termite infestations, the acoustic device pinpoints the exact location of a termite nest behind walls rapidly, accurately and non-destructively.
    Patent No. 7,429,928 - Method to Prevent Termite Infestations by Modifying Termite Behavior: This patent covers HomeSafe's method to prevent termite infestations in a house by generating very low-amplitude acoustical vibrations within the house's interior walls. These vibrations, which are inaudible to the human ear, disturb and repel termites and them out of the house. The specific vibrations have a custom-selected frequency and amplitude experimentally proven to be highly effective at modifying termite behavior.
    Additional Patent Applications Currently Under Review:
    11/158,109 EIFS and Moisture Inspection with Infrared
    12/194,977 Infrared, Moisture and Mold Sampling
    12/234,958 Identifying Structural Defects and Infrared
    12/209,590 Infrared, Temperature Profile Databases and Exhaust Blowers
    11/893,240 Application Dispatched from Pre-Examination -Not Yet Docketed
    To learn more about our patents, simply visit the USPTO’s Web site and perform a search at US Patent Full-Text Database Number Search.
    Default Re: Flir E4
    I am a new home inspector, planning to buy a Flir E4 Camera. Does it pick up the floor heating flow? Thanks.
    I had to read that three times to get it. We "turn on the hydro" with an electrical breaker switch here. Our electrical power is supplied by hydroelectric dams by the BCHydro company.
    Yes the IR image shows exactly where the water pipes ended up after they poured the concrete. Very enlightening.
    Default Re: Flir E4
    Patent US7369955 - Method for residential indoor environmental quality inspection and monitoring - Google Patents
    Publication number US7369955 B2
    Publication type Grant
    Application number US 11/360,274
    Publication date May 6, 2008
    Filing date Feb 23, 2006
    Priority date Feb 23, 2006
    Fee status Paid
    Publication number US7445377 B2
    Application number US 10/708,571
    Publication date Nov 4, 2008
    Filing date Mar 11, 2004
    Priority date Mar 12, 2003
    Fee status Paid
    Publication number US7385483 B2
    Application number US 11/641,498
    Publication date 10 Jun 2008
    Filing date 19 Dec 2006
    Priority date 9 Oct 2002
    Fee status Paid
    Publication number US7434990 B2
    Application number US 10/711,248
    Publication date Oct 14, 2008
    Filing date Sep 3, 2004
    Priority date Oct 9, 2002
    Fee status Paid
    Publication number US7271706 B2
    Application number US 10/680,377
    Publication date Sep 18, 2007
    Filing date Oct 7, 2003
    Fee status Paid
    Publication number US7429928 B2
    Application number US 11/904,093
    Publication date Sep 30, 2008
    Filing date Sep 26, 2007
    Fee status Paid
    Below is an image I took in January, 2005:
    Default Re: Flir E4
    Tying this thread to the other thread with the same topic in it:
    - http://www.inspectionnews.net/home_i...tml#post242990
    Sep 2008
    so so, California
    Default Re: Flir E4
    So you guys still doing IR?
    Default Re: Flir E4
    Under the overcoat, like a dirty old man.
    Not.
    I'm Canadian. Safe from the sharks,for now.
    Sep 2008
    so so, California
    Default Re: Flir E4
    Not.
    So these guys still pursuing lawsuits? i live in CA so you'd think i'd be used to this by now..
    Default Re: Flir E4
    Looks like they are priming their pens based on the letter that was sent to thousands of inspectors across the country. All I can say is they appear to have a renewed vigor after the involvement of the owner of a large home inspector organization.
