    Default Extended TPR valve
    I called out the TPR valve on this water heater as improper as I was trained that you weren't allowed to use "Extensions" because the standard sensing element might not get far enough into the tank to be effective.
    I know there are TPR valves with "longer" sensing elements available, but don't know how I would identify them... and this just didn't look proper. The sellers plumber looked at it and originally said everything was fine... I am hoping he put that in writing, but may not have...
    What would you have called out or written?
    PS...the excess pipe dope doesn't count...
    Default Re: Extended TPR valve
    Good call
    Here are some Watts T&P relief valves with the extended sensor:
    - Temperature and Pressure Relief Valves, Water Safety & Flow Control, Watts
    Were you able to see the model number of that valve? The extended sensor one are all XL numbers.
    I couldn't get back to where I could get a clear view of the Model#... I might be able to take a picture "blind" and capture it. I get a chance later today as I got called back for a "Re-inspection".
    Wish I could find the old illustration that showed NOT to use extensions....
    For comparison to OP pict. notice the difference.
    Here's a standard unit.
    That is one model, there are multiple models with extension thermostats - the OP photos shows a body style somewhat similar to the 100XL, LF100XL, LF10XL, LF1XL and others.
    Nov 2009
    winslow, maine
    Why does it look like one of these, tpr-valve.jpgis screwed in to one of these?
    thCASJB45Y.jpgIs it possible the Manufacturer designed it that way?
    I would recommend looking at the Manufactures recommendation for this item.
