    Feb 2014
    Default Frozen Evaporator coil
    What are the potential issues with a Frozen Evaporator coil and Condenser coil. Thanks for the help!
    Capistrano Beach, CA
    Default
    Hi Omargarcia and welcome to InspectionNews!
    I hope you find everything you are looking for on this site.
    If I can help you in any way just let me know.
    If you are a business owner please accept this gift for making your first post: http://www.inspectionreferral.com
    If you are a home buyer, seller or DIYer, this gift is for you: http://www.inspectionnews.net/home-i...als/member.php
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: Frozen Evaporator coil
    Quote Originally Posted by Omargarcia View Post
    #1. Is this a heat pump?
    #2. What coil is frozen, (indoor or outdoor)?
    #3. Are you in Maryland, and what is the outdoor temperature and moisture?
    Jul 2014
    Fl
    Frozen coils require a tech on-site to evaluate, causes include: 1) Poor air flow - can be as simple as a clogged filter or as extreme as a bad motor 2) Incorrect refrigerant charge... where did it leak? 3) Contaminated refrigerant 4) Restriction in the metering device - moisture 5) Crushed or undersized duct work 6) Mismatched equipment or a combination of multiple items. This condition MUST be remedied - left unattended will wash the bearings out of a compressor.
    Quote Originally Posted by Dave Borowski View Post
    May be nothing wrong with it - if it is a heat pump and it is the outdoor coil which froze up ... stand there for a while and it might go into defrost most and defrost itself.
    Inside coil is a different issue, but I doubt the a/c was running in this weather ...
    (Well, okay, I had the a/c on in the vehicle today while out doing inspections, but that's "down here".
