Thread: Stucco
04-12-2007, 10:12 AM #1
Stucco
04-12-2007, 03:04 PM #2
Re: Stucco
The 2" clearance, no.
The foundation weep screed along the foundation, yes.
Proper screed along the brick, yes.
But 2" clearance, no.
04-12-2007, 04:18 PM #3
Re: Stucco
Please put your location in your profile.
04-12-2007, 06:01 PM #4
Re: Stucco
That would just expose framing, or siding, or sheathing, or something.
You need the 2" clearance above a roof, etc., but, for a foundation, you want the stucco/metal lath/paper/paper/sheathing/foundation weep screed to extend over the foundation/wall joint.
With the vertical side, you want the screed to be adjacent to (approximately 1/8" - 1/4" from) the brick/wood/whatever to allow for a caulk joint from the screed to the other material. The stucco is plastered up to and into the screed, leaving the 1/8" - 1/4" joint open to accept the caulk/sealant.
