03-22-2017, 04:52 PM #1
AC CONDENSER DRAINING INTO SINK DRAIN
GUYS---IS IT OK to have the ac units condenser pipe draining into bathroom sink drain pipe if there is a vent stack under that sink--never saw this before thanks cvf
03-22-2017, 06:38 PM #2
Re: AC CONDENSER DRAINING INTO SINK DRAIN
CVF,
I'm not sure what you mean by a "vent stack under the sink". Are you referring to an AAV?
Anyway, I believe you can drain condensate into a tailpiece, but before the trap. After the trap and you run the risk of sewer gases venting back into the HVAC system.
03-23-2017, 05:01 AM #3
There should be an air gap, usually we find these draining into the washer drain with an air gap
http://www.jjeffzehnder.com/
03-23-2017, 08:53 AM #4
03-23-2017, 09:42 AM #5
03-23-2017, 11:55 AM #6
Appears to have jumped threads with my reply
Here is the thread I jumped to not of my own accord.
http://www.inspectionnews.net/home_i...blue-glue.html
That appears to be a class of PVC or schedule 40 pipe (DWV)
Hope it is schedule 40.
No AVV.
PVC Hot Blue LAVA Cement.
Its wrong IMO.
Attached thread explains.
