    Seth Hughes's Avatar
    Seth Hughes Guest
    Default Water Heater in bathroom closet
    comments? and suggestions for what to say? thanks in advance for any replies
    Default Re: Water Heater in bathroom closet
    Quote Originally Posted by Seth Hughes View Post
    Seth,
    As this is an Electrical Appliance location isn't an issue.
    It does need a flow pipe with a 2" air gap for the TPR valve.
    Needs a catch pan and drain installed.
    Receptacle needs a cover installed.
    Seems pretty obvious to me. Why are you asking?
    Tampa, Fl
    Water heater appears to be amateur installation. Among the deficiencies are lack of TPR valve extension, unprotected Romex-type wiring, lack of proper wire clamp. Recommend full review of water heater system and repair as needed by licensed plumbing/electrical contractor.
    Quote Originally Posted by Matthew Barnicle View Post
    Matthew,
    That's just asking for the same plumber who installed that joke to come back in and bless his installation.
    Instead, say it this way:
    First, list everything you see wrong, then ' "repair as needed by licensed plumbing/electrical contractor" including but not limited to all above noted items and any other items found or created during those repairs'.
