Results 1 to 24 of 24
Thread: pvc pipe from pressure relief
02-19-2008, 09:39 PM #1
I came across a white pipe off of a tpr valve today that looked just like pvc. Of course, I thought it was wrong but for some reason I knelt down to read the pink writing on it. It said it was rated for use as a pipe off a tpr for any unit up to 100,000 btu's.
I snapped several pictures but, as most of you can relate to, trying to snap a picture of small pink writing on a small white pipe doesn't always work.
It wasn't stamped with any recognizable brand or type of pipe, just that it was okay for use as I noted above.
Has anyone run into this stuff? If so, what is it? I've just always assumed when it's bright white it's pvc.
02-19-2008, 09:46 PM #2
Re: pvc pipe from pressure relief
I can't remember if I seen them a Home Depot or Menards. Cheap and easy to install. They have one that is designed when the TPR valve is on the side of the water heater and one that is designed when the TPR is on top of the water heater.
Note sure what it is made of.
02-19-2008, 09:59 PM #3
I've seen it but I don't know much about it. I figured since it is marked, it must be OK.
bruce
Bruce Thompson, Lic. #9199
www.TylerHomeInspector.com
02-20-2008, 07:03 AM #4
In addition to just stating it was okay for that use, it should also have had some standard or approval numbers, such as ASTM, ANSI, ICC, "something" to indicate it had "third party" testing and approval by some authority.
If all it had was writing stating it was okay to use for a T&P discharge pipe, I would write it up for the plumber to make appropriate repairs or to provide documentation that this is suitable for this use.
Many times, if the plumber is not familiar with the material, instead of spending time to find the documentation, they will just replace it. If they have already had to supply this documentation to the AHJ, they will just whip out that documentation and say something to the effect of 'Jeez, I've already given this stuff to the plumbing inspector, how many more people do I have to show it to?' (Answer: Anyone who asks for it.
That's the perils of using non-standard material and trying to save 50 cents.)
02-22-2008, 06:15 PM #5
Did it look like this?
02-23-2008, 09:03 AM #6
It could have been white PEX.
02-23-2008, 01:19 PM #7
That pipe Matt's describing sounds like the thin PVC or polyethylene TPR extension tubes sold at home centers.
I'll try to find a photo of one later.
Dom.
02-23-2008, 02:12 PM #8
That's pretty much all we see up here.
BTW, keep the kids away or they'll end up with hot tootsies.
02-24-2008, 10:45 AM #9
Jake's picture is likely Harvel series SDR PVC that is rated at 140° F. and not an approved material. That installation also shows threaded fittings in the line which are not allowed.
John's picture has a number of problems with it not the east of which is that the drain line is undersized and likely not an approved material.
I don't see anything being used in my area other than CPVC, the most of which is both undersized and improperly installed.
Aaron
02-24-2008, 12:14 PM #10
I had to go to the orange box this morning due to a leaky sink strainer basket.
While I was there I think I found what Matt was referring to. There is not any type of listing stamped or printed on the pipe itself.
It reads: Hand Tighten Only T&P Valves With 10,000 BTU Or Less Rating AllPass
I snapped a couple of pics with my phone.
02-24-2008, 02:50 PM #11
02-24-2008, 03:35 PM #12
John:
In Canada the gas utility may be the code authority and also override the TPR valve manufacturer's installation instructions. ASTM, UL et al. many not mean squat in the land of the midnight sun. That is not the case here in the land of the IRC.
Aaron
02-24-2008, 06:27 PM #13
Jake,
What did it say off to the left in your first photo? "#1548.........."? Then something else I cannot make out.
02-25-2008, 02:37 PM #14
Jerry, that number doesn't show up in the original photo I have either.
It's a sticker with the home depot item number and bar code.
02-25-2008, 03:07 PM #15
I found this on the Watts Canadian site. Maybe this is the creature?
Aaron
http://www.wattscanada.ca/pdf/ES-100DT.pdf
02-25-2008, 03:10 PM #16
Jake,
I thought it might have been some kind of standard number, but it wasn't.
Saying that it can be used for a water heater T&P relief discharge line is like saying one can use a gun to shoot oneself with - it's not recommended, but, sure, it *can* be done - just not a real good idea.
Not sure there is a law against shooting oneself either, I mean, who are they going to charge for breaking the law - the dead body? "Hey, you there, laying on the floor, you are being charged with discharging a fire arm in the vicinity of one's head, leading to and causing the death of oneself." Yeah, right.
At least, though, with the white pipe, the code says don't use it for that unless it has been tested, listed, and labeled for that use, and, if you do use it when it has not been tested, listed, and labeled for that use, *YOU* are at fault, and *YOU* ain't "dead". (Not "you" as in you personally, but as in "you" being whoever did it.)
02-25-2008, 03:17 PM #17
Maybe we can get Diamond Tony to test this gun theory for us . . .Saying that it can be used for a water heater T&P relief discharge line is like saying one can use a gun to shoot oneself with - it's not recommended, but, sure, it *can* be done - just not a real good idea.
Aaron
02-25-2008, 03:22 PM #18
02-25-2008, 03:47 PM #19
02-25-2008, 05:16 PM #20
I was in the big orange box today and saw the same discharge line, It did not look like regular pvc though... Watts was listed as the manufacturer but I did not see any standard listing number on the pipe.
I'll check on the Watts site.
02-25-2008, 05:21 PM #21
This is from the Watts site.
BTW these did not have threads on the discharge end although the shorter one had an outer sleeve that could look like threads in a picture.100DT
Drain Tubes for Side-Mounted T&P Relief Valves
Size(s) :
3/4 in. (20mm)
Description:Series 100DT Drain Tubes for T&P Relief Valves are used on gas, electric, or oil fired residential water heaters to safely drain water discharged from the heater's temperature and pressure relief valve. It connects to the drain connection on a side-mounted relief valve that has up to 100,000 BTU/hr. rating, and has a drop length of 48 in. or 72 in. Series 100DT hand tightens to relief valve outlet, requiring no special tools or fittings. UPC and IAPMO listed, ASME A112.4.1 approved. Meets Department of Housing and Urban Development requirements. Maximum Working Pressure: 15 psi (103 kPa).
02-25-2008, 05:30 PM #22
Billy:
Now that's what I'm talking about . . .
Aaron
02-25-2008, 05:33 PM #23
Billy,
Yep, that's the one.
02-25-2008, 05:35 PM #24
Hey Matt,
Jerry Peck hit it on the money as it requiring to be "listed", that said, if it does not meet the UL listing it shall not be used.
I did see some comments re Canada and the States, as to the Good Ol' U S of A, the T&P discharge line should be smooth bore to its point of discharge, no threaded points to its termination, other than its point of attaching to the T&P directly.
Also, there was some PEX piping showing on one set of pics as noted by the crimp rings...PEX is not an authorized material for T&P relief valves.
Anyhow, just throwing my two point five cents into the mix.
Take care,
Pat
