Results 1 to 12 of 12
    Kendall Goad's Avatar
    Kendall Goad Guest
    Default Water Heater Plumbing
    Any comments on this plumbing job.
    There are no leaks at current, but something just doesn't seem right.
    Default Re: Water Heater Plumbing
    Quote Originally Posted by Kendall Goad View Post
    But it is Leaking. ( Carbon monoxide. )
    I'd write it for the Safety Hazard & Apparent Amateur Installation to be corrected by a licensed plumber.
    Kendall Goad Guest
    Maybe I should have said no water leaks.
    But you are right I did write it up for possible Carbon Monoxide leaks.
    Possible (?)
    Kendall,
    All kidding aside the plumbing is a mess.
    Whats with the 2 supply lines coming in ?
    Could you see where they were coming from ?
    I really like the bonding clamp on the plastic pipe.
    Kendall, you really need to work on your flash photography
    Kendall Goad Guest
    Kendall,
    The smaller line is actually to the Ice Maker on the Refrigerator.
    The other line disappears into the wall and I could not trace where it goes. Nobody else seems to have a clue.
    No kidding. For some reason I could not get this one to come out right.
    I took about 4 different photos and this was the best.
    First, that vent has fallen to one side.
    Second, all those plumbing lines need to be supported properly before bending like that.
    Third, that plumbing needs to be protected from the vent heat (6" clearance from the draft hood minimum)
    Where is the T&P?
    New Mexico
    Second line is probably swamp cooler, maybe no longer in use?
    Tampa, Fl
    "Amature installation at water heater. Among the deficiencies/deficiencies include improper pipe support and/or clearance to vent and improper venting/risk of carbon monoxide for example. Recommend full review of water heater system and repair as needed by licensed plumbing contractor experienced and licensed for gas fired systems"
    Healdsburg, CA
    And the Lord said, "let there be light!"
    (nice door stop?)
    Jerry McCarthy
    Kendall Goad Guest
    (nice door stop?)
    There are problems with the door framing, but luckliy it does open away from the WH.
